a client (one who is concerned about wifi radiation....) requested to have the radios of e410 APs turned off from 10pm to 6am.
I've only found a possibility to scheduled turn off a wlan, but not the radios. Is it somewhere hidden?
aero
aero
Hi Aero,
WLAN>Schedule Access helps you to schedule turn off/on of a WLAN
Regards
Anand
Hi Anand,
thank you for your reply.
My understanding is that Schulded Access will only disable the ssid for the given time setup. But will not shutdown the radio?
Theres a function in the ap setup that would be what's needed, but you can't schedule it:
btw: there's a bug in the cnMaestro portal. If you setup a schudule and want to delete it (clear the fields) I get the error: Scheduled acces value for sa1 is invalid.
cheers
aero
Hi Aero,
Along with the WLAN, the radio is also disabled.
Regards
Anand
