Hi all.
To import your own digital certificates on to cnMaestro via web console (and avoid the error message in spash page for your guest access) you can follow the steps below:
1) you need 3 files of your company digital certificates: "key.pem", "cert.pem" and "CA-trust.cert"
2) open all 3 files with a text editor and copy the content from "BEGIN" to "END" in another file with .pem extension (for example import.pem); follow the sequence: key.pem, cert.pem and last CA-trust.cert. You should obtain a file (import.pem) with 3 different session "BEGIN" - "END" (don't leave blank lines).
3) save the file "import.pem"
4) open cnMaestro web console and navigate to Application > Server > SSL Certificates > Import and select "Import Signed Certificate and New Key", click on "Select file" button, selct "import.pem" file and click "Import" button.
That's all.
Bye.
Enrico
