How to log in to ePMP after reset
How can i relogin to an epmp radio after reset as an admin when admin/admin failed
Try to clear your browser’s cache, or try a new/different browser.
Hullo Eric
Thanks for the reply but it also failed
Eric it only allows me as an installer
It looks like with the installer login you can try defaulting it again. Make sure “Retain Passwords” is disabled.
i have tried that also but has failed
Pretty odd. does the old admin password work on it?
You can use installer for both username and password.
Hi, how did you reset the ePMP radio? Are you certain it was successfully defaulted?
