Cambuim ptp 450
How do I reset my device? There is no normal reset button. There is some kind of hole - what to put there?
Thank you for your help!
Cambuim ptp 450
Hello Sir,
use the default IP address 169.254.1.1/16 to reach radio.
Put for example 169.254.1.4 with subnet 255.255.0.0 and startup the radio, as soon as it get power, try to reach the radio on 169.254.1.1 several time. You will have a page where you will two options: default boot or normal boot.
Choose the default boot. The radio will then give access to the configuration page and you will be able to edit configuration. To reset it, go to Unit settings, then click on set to factory default, save and reboot.
Sincerely yours,
Niragira Olympe
