Hi Eric,
How to test the throughput of PTPT 670 on it’s Website Page ?
The PTP6X0’s don’t have a built in speed test. They do show you the maximum available throughput updated regularly… which I’ve found to be reliable.
Hi Eric,
Thanks a lot of your help,
I need show the throughput data my client.
Do you have any suggestions,I can show the data.
Thank you ! let me try it
I use the iperf 3 to test the throughput .
Like this connection
PC–>PSU → Bottom LPU ----cable → top LPU → .ODU ---------- ODU → top LPU ----cable -->Bottom LPU → PSU–> .PC
but only up to 100M
PC–>PSU —>----cable → top LPU → .ODU ---------- ODU → top LPU ----cable → PSU–> .PC
It can up 1000M
the LPU had directionality?
It can up 350M
PTP-LPU model No.A005030 transfer Rate is 1000 Base T?
