Hello ALL;
I really want to know how to turn down the power level on my canopy’s. I have tried checking on the configuration pagfe but cant find where, could somebody help me ?
Blink
RF?
Configuration Page -> Transmitter Output Power (dBm)
hope that helps
Depending on the radio, you will either have the ability to adjust power in dB, or you will simply have Normal and Low
Low is -18dB compared to Normal.
