I am still new to Cambium, but on Airmax they give the total Airtime % in the GUI so I can use that to determine if the AP is running near full load. When running in a flexible TDD I just use the total %, but in fixed TDD on Airmax I use the Airtime % based off the DL ratio. So if I have the AP set to 67/33 when the reported Airtime % is around 65% I consider the AP running near full capacity.
On ePMP 4K I see the Downlink Frame Time % is listed under Monitor->Performance. How do I interpret this value? If I am running a 75/25 split do I consider the AP near max when Frame Time is near 75% or 100%?
I did some tests by doing a single SM and then a double SM link test and on a single SM the Frametime did not exceed around 42.6% while on a double SM link test it would top out around 67.2%. Shouldn’t the link test force the AP to around 100% DL Frame Time used?
