Hello everyone, I am trying in all frequency bands to improve the following link and it has not been possible, some suggestion, the distance between each node is 3KM
- Spectrum extended.png (131 KB)
- Status.png (76 KB)
What are your limits?
(In other words, what are you not allowed to do?)
Are you only interested in changing frequency, or can you...
- raise/lower the antenna(s)
- position the antenna(s) to take advantage of boundaries (walls, buildings, machinery, HVAC, etc.) that might block interference
- use ultra high performance antennas
- use larger antennas with narrower beamwidths
- identify potential interference sources and use RF screens to block them
- reduce the channel bandwidth
- increase the transmit power
- reduce the modulation mode
- use DFS to let each end of the link decide what's best
- etc.
In some cases, this is like trying to balance a marble on top of a bowling ball--one parameter directly affects another parameter. (For example, reducing the modulation mode can improve interference performance, but it also reduces the throughput.)
Dave
