We had several nodes drop at near the same time over the weekend… When I try to initiate a link from the DN, I get an error, “Initiator node is not qualified, current state ONLINE.” Before I reboot the DN, which is also a POP, I am trying to figure out what has happened. I am attempting to wait for support to respond, but I was hoping someone else has experienced this and knows the quick solution.
This means DN does not have GPS Sync.
Are you trying in a lab environment, where there is no GPS ? If yes, please try selecting (i) Force GPS disable in Config->Radio->GPS section (ii) Short Range optimized in Config->Radio-> IBF Transmit Power section
