I am trying to set a specific Ip address on a interface VLAN. When I check the configuration it shows me a # on the Ip address and on top it says “no ip address”. I have assigned the VLAN to a port and had a device plugged in. When I check the config, the results are the same. I have deleted the interface vlan and re-added, with no shutdown, still no change. I have added to the GUI, as well. On the running config it still show the # symbol on the ip address and says “no ip address”
Is there a configuration I am missing to remove the # from the config?
interface vlan 1
# ip address dhcp
ip address 192.168.1.1 255.255.255.0
no shutdown
ipv6 enable
interface vlan 210
no ip address
# ip address 10.128.3.254 255.255.254.0
no shutdown
