Hi Gents
that two PTP 600 Links I use It , I Have Strong Interferance On Both Links
So Any Body have Solution To Avoid this Interfernce Or there Is Any Other Equipment I Can Use It To Prevent This Interferance From My Link
Regards
Hi Gents
Regards
Hi Mohamed,
I would like to know if these 2 links are on the same tower or on 2 different towers. If they are on the same tower, we can use a PTP Sync unit which will help you in minimizing the self intereference.Â
Regards,
Vivek Gupta
Hi Mohamed
As you ask for other equipment options, I would recommend the PTP450i in high-interference environments. We've had them outperforming even the PTP650 when the noise floor has been exceptionally bad; the new dynmic  interference filter really works well.
Our test link had such high noise a 650 was unable to maintain a stable link in 20MHz channel, and we ran it in 5MHz channels as a result. The 450i was able to use the 20MHz channels and increased throuput as a result of using 20MHz vs 5MHz.
-Kyle
