in our network we have nearly 26 links that works with PTP 58600, there’s links to 30MHz, the other with 15Mhz and there also with 10 and 5.
where we have more than 2 links in a point, use PTPSYNC.
I worked the whole map with LINKPlanner respecting all timing calculated.
my question, is there a software that allows LINKPlanner as set frequencies for each link to remove interferences.
otherwise how can I determine the frequency manually.
I can send you the map on LINKPlanner studied.
thank you
Hi
PTP-SYNC is really a benefit when you have multiple PTP devices and you are operating them on the same frequency - It helps to avoid self interference.
Trying to “Frequency Plan” is a complex task, and you will need to know what PTP links you are planning as well as other equipment that you have operating in the band, and what frequency those units are using - They should be included in your frequency plan as well.
The most difficult part is understanding what other users are doing in the unlicenced band - You won’t have any control over their frequency use, but understanding where they are operating will help you plan.
Before you start planning, you can use the Spectrum Management mode of a PTP device in Slave mode to scan the band and find out what frequencies are occupied by existing equipment.
If you need any specific help with your LINKPlanner file then please raise a case at support@cambiumnetworks.com and we will assist.
Julian
