:x Is it possible to down grade an AP from 7.3 to 7.2, I’m having link problems after the upgrade. Links that the jitter was 3/4 is now 3/15, link test reflects that.
Yes, why not?
What scheduling do you use? We do have HWS and quite good experience with 7.3.6.
We also us HWS, after the upgrade the link went to the crapper.
What did you upgrade?
AP, SM, BH, etc
What version of hardware. P8, P9?
If P9 is it Advantage?
We upgrade the AP and the SM’s. I think we are running the P9’s and the software is branded Advantage.
I find it odd that you are getting poorer performance. You might want to spend a little more time to figure out what’s going on. 7.3.6 works very well.
