I am a new user how to manage customers by giving them data capacity. Once the capacity is reached, it will be disconnected from the Internet.
Is it possible to manage this with cambium which version and how? If a member can help me.
I would be happy to read you
PFR
(Pshemo (przemo))
January 2, 2023, 5:54am
#2
With WiFi it is possible. For radio client is rather not possible from cnmaestro
Pshemo (przemo) thank you for your answer.
With Cambium Networks cnPilot e510 outdoor I can manage customers by giving them access with Megabytes?
For example: a customer x asks for 5GB and I offer him 5 GB valid for 24 hours. If it reaches 5GB before 24 hours it will be disconnected from the network and after 24 hours the package becomes 0GB.
Can I have a link where we can explain how it works?
PFR
(Pshemo (przemo))
January 2, 2023, 7:25am
#5
Go to the guest access portal rule.
Set quota limit (total or directional )
If you are using vouchers there is simple way
PFR
(Pshemo (przemo))
January 2, 2023, 7:41am
#6
In your sample just create special Vouchers: 5Gb/24h or 10Gb/36h or something else
Customer will use voucher dedicated to his needs
Pshomo Thank you very much for your help
