Is VLAN supported for Management and customer data on ePMP? (separate or together)
Answer: There is a Management VLAN that is configurable from 1 to 4095.  There is a Data VLAN (Port VID) that is configurable from 1 to 4095.  They can be configured as the same VLAN ID or as different VLAN IDs.  Membership VLANs can be defined via a range.
