Java applet stuck on random % on screen.
Issue Brief:-
While launching WM from webbrowser WM Cambium Networks applet stuck on at radom % value.
Problem Root Cause:-
64bit Java installed or incorrect license file causes issue
Resolution:-
In order to resolve this uninstall java 64bit and install java 32bit. Also make sure that C:\Cambium\License manager\Flexnet\License_files\ should have desired license file (trial or purchase one).
Regards,
Deepesh Chandra Sharma.
Technical Specialist-L3 Networks.
Cisco Certified Network Professional.
Cambium Certified over PMP/PTP/ePMP.
