After upgrading from 7.3.6 to 8.1.4 and later 8.1.6 i have noticed that the jitter is too high. Sometimes it goes up to 9-10 even with power level -68 to -70 . Is there any issue with that?
I hope the new firmware 8.2 will address it.
Have any one encounter this?
Bruno
Radio running in 1X or 2X? If the radio is just between the threshold of 1X and 2X, sometimes it’s better to just force to 1X
If the radio is running on 1X already, then it’s likely interference however a broadcast storm can also cause higher jitter to packet flooding.
It should be noted that jitters of 9-10 are acceptable when the link is in 2x mode.
