JSON Help
I am running into some problems with the JSON editor through cnMaestro. I have figured out how to set frequencies on 20 mhz, but can't get it to add 40 mhz while still keeping the original 20 mhz as a backup. Could somone help out and let me know what I am missing? All it is doing is adding the 20mhz channel. This is what I have on my template.
 "device_props": {
        "wirelessInterfaceScanFrequencyListTwenty": "5740",
        "wirelessInterfaceScanFrequencyListForty": "5750"
Are both 20 Mhz and 40 Mhz enabled on the device?  This setting is stored in wirelessInterfaceScanFrequencyBandwidth.  If only those two brandwidths are enabled the value would be "3".
  "device_props": {
    "wirelessInterfaceScanFrequencyBandwidth": "5"
I believe this will enable 10 and 20mhz. And if you change the 5 to 3 as mentioned in the other post you should be good.
Only 20mhz is enabled on the device. I would like to enable the 40mhz while still retaining the original 20mhz as backup and change the 40mhz channel as needed.
easiest thing to do is download the config off a radio that is set up how you want and then search for the
string and see what the value is.
