GOAL
Basically 2 SSIDs v5 and v15 in e410.
If I connect to v5, I'll get vlan5 ip
I need guidance from Cambium
or Cambium can reproduce my issue by copying my Mikrotik setup
tq
PROBLEMS:
1. I can't get dhcp when I connecting my pc to v5 or v15 ssid in e410
Tunnel in Mikrotik or Cambium side shown up
CONFIGS:
Cambium L2TP documentation using BCP
CAMBIUM
management user admin password $crypt$1$AVMSLfGfB7AT6ZjEJUi6IsdkuWApwB2R
no management http
management cambium-remote
management cambium-remote validate-server-cert
management https
management http port 80
no management telnet
management ssh
management https port 443
led
lldp
no poe-out
country-code CN
wpa2-handshake-retry 4 4
wpa2-handshake-timeout 100 500 1000
wpa2-handshake-log-level 4
placement indoor
wireless radio 1
no shutdown
channel auto
channel-width 20
channel-list all-channels
data-rate unicast 1b 2b 5.5b 11b 12 18 24 36 48 54
data-rate non-unicast highest-basic
power auto
mode gn
no airtime-fairness
auto-channel-select on-startup
antenna-gain 5
beacon-interval 100
dynamic-channel-selection
dynamic-channel-selection threshold 100
dynamic-channel-selection samples 20
off-channel-scan dwell-time 50
auto-rf chan-hold-time 120
auto-rf packet-error-rate-threshold 30
auto-rf channel-utilization-threshold 25
mesh-xtnded-dev-list
wmm-parameters downstream txoplimit vi 3008
wmm-parameters downstream txoplimit vo 1504
wmm-parameters upstream txoplimit vi 3008
wmm-parameters upstream txoplimit vo 1504
wireless radio 2
shutdown
channel auto
channel-width 80
data-rate unicast 6b 9 12b 18 24b 36 48 54
power auto
no airtime-fairness
antenna-gain 5
beacon-interval 100
wireless wlan 1
ssid v5
no shutdown
vlan 5
security wpa2-psk
no protected-mgmt-frames
passphrase $crypt$1$8gTOHx5MAAbUnAJJwRefP868Ec9c+Zt6
band 2.4GHz
dtim-interval 1
max-associated-client 127
client-cache cnMaestro
tunnel-mode
mac-authentication policy deny
passpoint interworking access-network-type private
no guest-access
dhcp-option82
dhcp-option82 circuit-id vlanid
dhcp-option82 remote-id vlanid
wireless wlan 2
ssid v15
no shutdown
vlan 15
security wpa2-psk
passphrase $crypt$1$iXEbXsvsHfPr/UQt7PrPzffMcljmLcrX
band 2.4GHz
dtim-interval 1
tunnel-mode
no guest-access
dhcp-option82
rogue-ap detection
interface eth 1
switchport mode access
switchport access vlan 1
interface vlan 1
ip nat inside
ip dhcp request-option-all
ip address zeroconf
management-access all
ip address 192.168.88.228 255.255.255.0
interface vlan 5
ip nat inside
ip address 10.0.5.228 255.255.255.0
interface vlan 15
ip nat inside
ip address 10.0.15.228 255.255.255.0
tunnel encapsulation l2tp
tunnel l2tp
remote-host 192.168.88.11
pmtudisc
tcp-mss 1400
auth admin $crypt$1$x9VEbiKcHlFefdNxLZXBMcwAcs5FXBas
tunnel l2gre
dscp 0
mtu 1500
tcp-mss 1410
ip route default 192.168.88.1
ip name-server 8.8.8.8
ip name-server 9.9.9.9
dhcp-option82 vlan 1
timezone Asia/Jakarta
hostname E410-97ACF5
snmp-server
ip gw-source-precedence static 1
ip gw-source-precedence dhcpc 2
ip gw-source-precedence pppoe 3
logging syslog 7
MIKROTIK
RB951
/interface bridge
add name=bridge1 vlan-filtering=yes
/interface l2tp-server
add name=L2TP-in1 user=admin
/interface gre
add disabled=yes dscp=0 !keepalive local-address=192.168.88.11 mtu=1500 name=\
gre-tunnel1 remote-address=192.168.88.228
/interface vlan
add interface=bridge1 name=v5 vlan-id=5
add interface=bridge1 name=v15 vlan-id=15
/interface wireless security-profiles
set [ find default=yes ] supplicant-identity=MikroTik
/ip pool
add name=poolv5 ranges=10.0.5.101-10.0.5.200
add name=poolv15 ranges=10.0.15.101-10.0.15.200
/ip dhcp-server
add address-pool=poolv5 disabled=no interface=v5 name=dhcp-v5
add address-pool=poolv15 disabled=no interface=v15 name=dhcp-v15
/ppp profile
add bridge=bridge1 name=pppBridging
/interface bridge port
add bridge=bridge1 interface=ether2 pvid=5
add bridge=bridge1 interface=ether3 pvid=15
/interface bridge vlan
add bridge=bridge1 tagged=bridge1 untagged=ether2 vlan-ids=5
add bridge=bridge1 tagged=bridge1 untagged=ether3 vlan-ids=15
/interface l2tp-server server
set default-profile=pppBridging enabled=yes max-mru=1500 max-mtu=1500
/ip address
add address=192.168.88.11/24 interface=ether1 network=192.168.88.0
add address=10.0.15.1/24 interface=v15 network=10.0.15.0
add address=10.0.5.1/24 interface=v5 network=10.0.5.0
/ip dhcp-server network
add address=10.0.5.0/24 gateway=10.0.5.1
add address=10.0.15.0/24 gateway=10.0.15.1
/ip dns
set servers=1.1.1.1,9.9.9.9
/ip firewall nat
add action=masquerade chain=srcnat
/ip route
add distance=1 gateway=192.168.88.1
/ppp secret
add name=admin password=admin
PC1
/ip address
add address=10.0.5.11/24 interface=ether2 network=10.0.5.0
/ip route
add distance=1 gateway=10.0.5.1
PC2
/ip address
add address=10.0.15.11/24 interface=ether3 network=10.0.15.0
/ip route
add distance=1 gateway=10.0.15.1
