I have a switch that i’ve changed to provider-edge mode so i can do QinQ, all ether-types are set to 0x8100 for compatability, all ports are tagged only.
When I plug a non-LACP port on the cnMatrix to a 3rd party switch i can access the cnmatrix remotely and ping it.
When I enable LACP on that same 3rd party switch port and move the cable to one of the cnMatrix’s ports thats in a LACP LAG group, the LAG seems to come up on the remote side, but i can’t ping the cnMatrix.
The vlan i’m using for in-band management is on the po1 and the non-lacp tagged port but only the non-lacp will allow ping/connectivity, the po1 member port won’t pass traffic.
