I have two sectors 60 degrees with epmp 1000 without GPS , a sector with 9 customers with high level snr customers in around 35 db and high rates mcs 13/14/15 but noticed an increase in latency of customers in this sector as attached image , sector with 9 customers with this ip 192.1.1.10 192.1.1.13 with 5 customers , this with 5 customers do not display high mcs levels and signal as another difference though sector average latency between the two is 10 ms . I think average latency of 25 ms in the sector with 9 customers and too high for few customers , this expected latency with so few customers connected and low use ! ?
Two sectors same antenna configuration channel 20 MHz 75/25 ratio and 5ms frame size , only difference channel operation sector with 9 customers 5370 and 5425 5 customers .
Another question I have doubts if any advantage using fixed ratio on epmp without GPS or better use flexible .
In some tests in flexible mode greatly improves latency and bandwidth.
Latency avg 25 ms
latency avg 15 ms.
