LED
It would be very helpful if the Status LED’s were visible from outside the units. This applies to all types.
hello Sir …
may I studied from you, about Canopy Wireless
The “LED” 2.4GHz - Multipoint - Subscriber Modem
LNK/5 and
ACT/4
"doesn’t work"
why ?
I’m trying to default plug with short the pin 4 & 6 connector RG-11
but “doesn’t work”
:shock:
All the lights on every model I have used work. If the Link and Act lights don’t on yours I assume that you also cannot connect to the unit. If you use 568A or 568B you should be able to plug the unit into a computer and “talk” to it.
As for the default plug, you must insert it, power cycle the unit, and then it should be defaulted to factory settings.
