Hi everyone,
I have an existing PTP800 setup using 55MHz spacing. I have an 80MHz channel in the 10-11GHz band and want to take advantage of the extra spacing in a P2P link, what equipment would you recommend to go ahead with this?
Thanks for reading.
The PTP820S and PTP820C both support true 80 MHz channels. Details of PTP820S and PTP820C can be found on product web page.
Allen
Thanks Allenyu. Wasn't aware the PTP800 and 810 had been discontinued. I will view the 2 you mentioned, thanks.
