Link capacity Drop while using PTP58600
We have a link which is using the PTP 58600 running for a distance of 58.2 kilometers. The radios are both using the firmware 56800-09-10. The link used to have a link capacity of 100 mbps using the 30 MHz channel bandwidth. Now the link capacity has dropped to 4 mbps and we have to use the 5MHz channel bandwidth in order for the radios to associate. We have replace the RF cables and the dishes are Radios waves 6 feet 37.5 dBi. There is clear LOS between the two poin
Hi Tayamika,
Request to please upgrade the firmware version on PTP58600 as the 09-10 is a very old version. The latest version for the PTP 58600 is 10-08. Post which if the issue still persisits, we will have to check for interference.
If you need further support regarding the issue, please contact support@cambiumnetworks.com and they will be happy to help you.
