tried different ways :
Software upgrade and downgrade
reduce mcs
no luck
so what’s the problem
Hi Kito;
Here’s the problem…
You have a broken chain - a broken pigtail, water in a connector, a broken antenna, or something… but CH0 is a -88 (Oh, BTW, CH0 in the software isn’t necessarily the connector labeled CH0 on the radios)
The quick answer it to swap out that f110 and see. If you have a spare f11p you can save some time by just swapping the antenna element (the pipe with pigtails) and then you wont have to realign
