Link Capacity not full
Team,
In PTP650 it shows Running at maximum receive mode, but in Link capacity it shows 222 Mbps.
We applied full licence.
Plese guide me.
Regards,
K.Esakki
As seen in the screenshot, link is working with (single) - almost half the capacity -  not (Dual).  If the link is connectorized you have to check the RF tials connecting the (V) and (H).
If it is integrated, you have to be sure that the link is clear line of sight and try more alignment.
Thanks.
I note single payload operation and I assume this is not a link with SD.
Please check your V/H Ratio, LOS and of course,ensure you have not accidentally disabled dual payload in the configuration.
