I have a P10 BH20 that every once in a while loses its mind. when I put in the IP address to get to the unit it will come up with the motorola symbol but then when it is suppose to go over to the username and password screen it is blank. has anyone else seen this? the only solution is to go to the site and reboot the BH itself.
it functions properly, it will register to the other Bh just fine and pass traffic, it just doesnt allow you to get to the login screen.
Yes, I have tried rebooting the other side with no luck.
anyone seen this? or have a fix?
here is what my Event log looked like after I was able to log in, dont know if it was coincidence but can anyone tell me what the heck this is?
15:59:33 UT : Wed Nov 21 2007 : File src/osportucos_ii.c : Line 56 calloc1 failed, out of heap, size 294912
15:59:36 UT : Wed Nov 21 2007 : File webportglu.c : Line 99 Error writing to file system. 10, msg: (null)
15:59:36 UT : Wed Nov 21 2007 : File src/osportucos_ii.c : Line 56 calloc1 failed, out of heap, size 294912
15:59:36 UT : Wed Nov 21 2007 : File webportglu.c : Line 99 Error writing to file system. 46, msg: (null)
15:59:36 UT : Wed Nov 21 2007 : File webportglu.c : Line 99 Error writing to file system. 25, msg: (null)
15:59:36 UT : Wed Nov 21 2007 : File webportglu.c : Line 99 Error writing to file system. 7, msg: (null)
15:59:36 UT : Wed Nov 21 2007 : File webportglu.c : Line 99 Error writing to file system. 41, msg: (null)
15:59:36 UT : Wed Nov 21 2007 : File webportglu.c : Line 99 Error writing to file system. 1, msg: (null)
15:59:36 UT : Wed Nov 21 2007 : File webportglu.c : Line 99 Error writing to file system. 44, msg: (null)
15:59:36 UT : Wed Nov 21 2007 : File webportglu.c : Line 99 Error writing to file system. 3, msg: (null)
15:59:36 UT : Wed Nov 21 2007 : File webportglu.c : Line 99 Error writing to file system. 14, msg: (null)
15:59:36 UT : Wed Nov 21 2007 : File webportglu.c : Line 110 Error writing new line, 0
15:59:36 UT : Wed Nov 21 2007 : File webportglu.c : Line 99 Error writing to file system. 23, msg: (null)
15:59:36 UT : Wed Nov 21 2007 : File webportglu.c : Line 99 Error writing to file system. 8, msg: (null)
15:59:36 UT : Wed Nov 21 2007 : File webportglu.c : Line 99 Error writing to file system. 6, msg: (null)
15:59:36 UT : Wed Nov 21 2007 : File webportglu.c : Line 99 Error writing to file system. 47, msg: (null)
15:59:36 UT : Wed Nov 21 2007 : File webportglu.c : Line 99 Error writing to file system. 28, msg: (null)
15:59:36 UT : Wed Nov 21 2007 : File webportglu.c : Line 99 Error writing to file system. 22, msg: (null)
15:59:36 UT : Wed Nov 21 2007 : File webportglu.c : Line 99 Error writing to file system. 48, msg: (null)
15:59:36 UT : Wed Nov 21 2007 : File webportglu.c : Line 99 Error writing to file system. 17, msg: (null)
15:59:36 UT : Wed Nov 21 2007 : File webportglu.c : Line 99 Error writing to file system. 12, msg: (null)
16:07:33 UT : Wed Nov 21 2007 : File src/osportucos_ii.c : Line 56 calloc1 failed, out of heap, size 32
16:07:33 UT : Wed Nov 21 2007 : File src/sockintf.c : Line 119 FatalError()
16:07:33 UT : Wed Nov 21 2007 : File src/stack_dump.c : Line 143
Stack Dump information:
Current context Task: SOCK
Current Stack: 2%
Max Stack: 28%
Task Stack Dump:
0x0074efa0: 0x0000efa4 0x0074f000 0x0079a620 0x0074c4b4
0x0074efb0: 0x00000bff 0x0003000d 0x0071233c 0x007123fc
0x0074efc0: 0x00000000 0x00000000 0x00000000 0x00000000
0x0074efd0: 0x00000d05 0x01200200 0x0000fef4 0x00000000
0x0074efe0: 0x00000000 0x00000000 0x00000000 0x0074f4b0
0x0074eff0: 0x00000122 0x00000d94 0x534f434b 0x00000000
0x0074f000: 0x00000000 0x0074efa4 0x00000226 0x00002ffc
0x0074f010: 0x0000001d 0x0000006b 0x00000000 0x534f434b
0x0074f020: 0x00000000 0x00000021 0x007c329e 0x00190e8c
0x0074f030: 0xffffffff 0x0074f03c 0x00048f28 0x0011f9ec
0x0074f040: 0x00000077 0x00000000 0x00045a0c 0x00000000
0x0074f050: 0x00000001 0x0042190c 0x00d84800 0x00045cd0
0x0074f060: 0x00000000 0x0074f10c 0x00000010 0x00000001
0x0074f070: 0x0042190c 0x0042190c 0x00d84800 0x00047bd4
0x0074f080: 0x0042190c 0x0074f10c 0x00000001 0x00e05d34
0x0074f090: 0x00000000 0x00000000 0x00000000 0x00000000
0x0074f0a0: 0x00000000 0x00000000 0x00000000 0x00000000
0x0074f0b0: 0x00000000 0x00000000 0x00000000 0x00000000
0x0074f0c0: 0x00000000 0x00000000 0x00000000 0x00000000
0x0074f0d0: 0x00000000 0x00000000 0x00000000 0x00000000
0x0074f0e0: 0x00000000 0x00000000 0x00000000 0x00000000
0x0074f0f0: 0x00000000 0x00000000 0x00000000 0x00000000
0x0074f100: 0x00000000 0x00000000 0x00000000 0x00000010
0x0074f110: 0x00000000 0x00000000 0x00000000 0x00000000
0x0074f120: 0x00000000 0x00000000 0x00000000 0x00000000
0x0074f130: 0x000cddcc 0x00000000 0x0074f39c 0x0074f3f8
0x0074f140: 0x0074f454 0x00000000 0x00000000 0x00000000
0x0074f150: 0x00000000 0x00000000 0x00000000 0x00000000
0x0074f160: 0x00000000 0x00000000 0x00177ff8 0x00000000
0x0074f170: 0x00000000 0x00000000 0x00000000 0x00000000
0x0074f180: 0x00000000 0x00000000 0x00000000 0x00000000
0x0074f190: 0x00000000 0x00000000 0x00000000 0x00000000
0x0074f1a0: 0x00000000 0x00000000 0x00000000 0x00000000
0x0074f1b0: 0x00000000 0x00000000 0x00000000 0x00000000
0x0074f1c0: 0x00000000 0x00000000 0x00000000 0x00000000
0x0074f1d0: 0x00000000 0x00000000 0x00000000 0x00000001
0x0074f1e0: 0x330eabcd 0x1234e66d 0xdeec0005 0x000b0000
0x0074f1f0: 0x00000000 0x00000000
Return Addr: 0x0011780c
00:00:00 UT : Mon Jan 01 2001 : File src/syslog.c : Line 1181 System Reset Exception – Watchdog Reset
00:00:00 UT : Mon Jan 01 2001 : File src/root.c : Line 417 System Startup
00:00:00 UT : Mon Jan 01 2001 : File src/root.c : Line 422 Software Version : CANOPY 8.2.1 BH20-DES
00:00:00 UT : Mon Jan 01 2001 : File src/root.c : Line 426 Software Boot Version : CANOPYBOOT 1.0
00:00:00 UT : Mon Jan 01 2001 : File src/root.c : Line 436 FPGA Version : 092707
00:00:00 UT : Mon Jan 01 2001 : File src/root.c : Line 440 FPGA Features : DES, Sched
16:08:12 UT : Wed Nov 21 2007 : File src/syslog.c : Line 1283 Time set
16:21:27 UT : Wed Nov 21 2007 : File src/http_utils.c : Line 35 Reboot from Webpage.
16:22:06 UT : Wed Nov 21 2007 : File src/syslog.c : Line 1283 Time set
Monday Morning, here is what my event log looks like now…
Current Stack: 2%
Max Stack: 19%
Task Stack Dump:
0x0074efd0: 0x00000d05 0x01200200 0x0000fc6d 0x00000000
0x0074eff0: 0x00000122 0x00000924 0x534f434b 0x00000000
0x0074f050: 0x00000001 0x0042190c 0x00d21000 0x00045cd0
0x0074f070: 0x0042190c 0x0042190c 0x00d21000 0x00047bd4
11:31:36 UT : Sat Nov 24 2007 : File src/syslog.c : Line 1283 Time set
22:43:22 UT : Sat Nov 24 2007 : File src/osportucos_ii.c : Line 56 calloc1 failed, out of heap, size 120
22:43:22 UT : Sat Nov 24 2007 : File src/sockintf.c : Line 119 FatalError()
22:43:22 UT : Sat Nov 24 2007 : File src/stack_dump.c : Line 143
Current Stack: 2%
Max Stack: 25%
Task Stack Dump:
0x0074efd0: 0x00000d05 0x01200200 0x0000fd5d 0x00000000
0x0074eff0: 0x00000122 0x00000c34 0x534f434b 0x00000000
0x0074f050: 0x00000001 0x0042190c 0x00d5b000 0x00045cd0
0x0074f070: 0x0042190c 0x0042190c 0x00d5b000 0x00047bd4
22:44:02 UT : Sat Nov 24 2007 : File src/syslog.c : Line 1283 Time set
09:56:02 UT : Sun Nov 25 2007 : File src/osportucos_ii.c : Line 56 calloc1 failed, out of heap, size 120
09:56:02 UT : Sun Nov 25 2007 : File src/sockintf.c : Line 119 FatalError()
09:56:02 UT : Sun Nov 25 2007 : File src/stack_dump.c : Line 143
Current Stack: 2%
Max Stack: 19%
Task Stack Dump:
0x0074efd0: 0x00000d05 0x01200200 0x0000fd63 0x00000000
0x0074f050: 0x00000001 0x0042190c 0x00d5f000 0x00045cd0
0x0074f070: 0x0042190c 0x0042190c 0x00d5f000 0x00047bd4
09:56:41 UT : Sun Nov 25 2007 : File src/syslog.c : Line 1283 Time set
21:08:29 UT : Sun Nov 25 2007 : File src/osportucos_ii.c : Line 56 calloc1 failed, out of heap, size 120
21:08:29 UT : Sun Nov 25 2007 : File src/sockintf.c : Line 119 FatalError()
21:08:29 UT : Sun Nov 25 2007 : File src/stack_dump.c : Line 143
Current Stack: 2%
Max Stack: 25%
Task Stack Dump:
0x0074efd0: 0x00000d05 0x01200200 0x0000fcd2 0x00000000
0x0074f050: 0x00000001 0x0042190c 0x00d6e000 0x00045cd0
0x0074f070: 0x0042190c 0x0042190c 0x00d6e000 0x00047bd4
21:09:08 UT : Sun Nov 25 2007 : File src/syslog.c : Line 1283 Time set
08:20:50 UT : Mon Nov 26 2007 : File src/osportucos_ii.c : Line 56 calloc1 failed, out of heap, size 120
08:20:50 UT : Mon Nov 26 2007 : File src/sockintf.c : Line 119 FatalError()
08:20:50 UT : Mon Nov 26 2007 : File src/stack_dump.c : Line 143
Current Stack: 2%
Max Stack: 19%
Task Stack Dump:
0x0074efd0: 0x00000d05 0x01200200 0x0000fbf9 0x00000000
0x0074eff0: 0x00000122 0x000008f0 0x534f434b 0x00000000
0x0074f050: 0x00000001 0x0042190c 0x00d49800 0x00045cd0
0x0074f070: 0x0042190c 0x0042190c 0x00d49800 0x00047bd4
08:21:30 UT : Mon Nov 26 2007 : File src/syslog.c : Line 1283 Time set
13:00:02 UT : Mon Nov 26 2007 : File src/syslog.c : Line 1283 Time set
NOONE has seen this in their event logs?
