Already have 5.2 canopy system on site. Was wondering what the channel size is for the 300 MB BH solution and how it is powered? Also, will it work with a cmmMicro for timing purposes?
The 300 Mb solution is a OEM from Orthogon Spectra, it uses a 30 mhz channel on both pol. it wont interfere with your 5.2 gear cause its 5.8 , it uses a propietary power supply with 55 vdc output and it wont sync with your micro…
Gino
So, how does timing work with the 300? I need to deploy 2 fairly close to each other, and am concerned with interference.
