At certain times I would get low RSSI on my broadband connection which results to an intermittent connection problem. I’ve already contacted my ISP so I could get the antenna readjusted but in the meantime are there settings in the canopy page that I could modify to increase my RSSI?
Thanks in advance!
You should look more at the jitter value and the link test results instead of RSSI. If you want to increase your dBm, Jitter, and link efficiencies then you can try to re-align the radio. Also, depending on the type of radio you are using and the SW version you may increase the output power.
