Manual for CLI
Can somebody direct me to a manual showing the ePMP CLI commands for a late version of ePMP firmware?
log into the gui and    hit    ?     and then enter.   some basic info will show up....
to look up all configurable options for example,   type    config set |      and press enter  (the vertical sold bar above back slash)
each option you can add ?  to get a list of options you can set.   many more them are 0 for disable and 1 for enable.
I don't have an actual guide aside from whats posted at support.cambiumnetworks.com/files
Hi Danny,
You can find latest CLI Manual version 2.4.3 on Downloads page for ePMP1000/2000:
https://support.cambiumnetworks.com/files/epmp/
Thank you.
