Maps are missing on cloud version of the cnmaestro.. Please fix it.
What version number?
Click on Satellite view.
The version is theĀ 2.3.0-r28, satellite view ? i cant see any button for that ....
Hi jdres -- it needs to be enabled in Application > Settings > Advanced Features. We turned it off by default, because it was experimental in the 2.2 release, but it has improved since then. Once set, you will get an option to switch between Satellite and Street View.
We hope to roll out a fix soon. It will not require a software upgrade. Seems the requests we are using are leading to issues with our provider, and we are currently evaluating our fix.
Hi jdres -- we got the fix out last night, and maps should be working correctly again.
