Hi, is it possibile to make massive modification to the sm(s) configuration? for example, if i have to change the color code or select specific channels, do i have to login into the sm one by one and change the configuration ??
Thnaks a lot
Mauro
Thnaks a lot
Mauro
Hi Mauro,
Yes, it is possible to push the configuartion to multiple SMs using the following tools.
1. cnMaestro:
a. Cloud based (https://cloud.cambiumnetworks.com)
Please visit the below to get the User Guide.
b. On-Premise.
Please visit the below to get the user guide and software.
https://support.cambiumnetworks.com/files/cnmaestro/
2. Wireless Manager.
Please visit the below to get the user guides and software.
https://support.cambiumnetworks.com/files/wireless%20manager/
Regards,
Vijay Gnanamurtthi
