What is the max distance that the power supply can be from the Canopy SM? 328 feet, same as Ethernet? Thanks.
We document and support the 328’ limitation imposed by Ethernet. Was there a unique scenario in which you were looking to go over 328’?
Is the Ethernet limitation on distance due to IR drop in the cable ? Would increasing the gauge of the power carrying conductors decrease the drop and increase the range ?
JayR :?:
