I know the maximum number of users is 200 with high performance turned off. What is the maximum number of users that you can actually deploy before it starts degrading the service for all of them? I guess another way to ask this would be, what is the maximum throughput per Advantage AP (combined throughput).
I am trying to figure out at what point, with my current speeds and users, I will need to add additional APs. I suspect it will be long before I hit the 200 users.
The aggregate troughput of an Adv. AP is >14Mbps (Uplink+Downlink). It depends on how much bandwidth you will get each customer. Normally you can oversubscribe.
I have asked something similar and here it’s the answer
http://motorola.canopywireless.com/support/community/viewtopic.php?t=1895
