hi community
what is the maximum link distance range for 450i
hi community
Official documentation says:
Maximum Deployment Range Up to 200 kilometers (124 miles) depending on configuration.
But there are many factors.
You can use link planner and see the link performance for your distance.
In PMP configuration (Point to Multipoint), the software limits the link to 40 miles (64 km).
In PTP mode, this range can be extended as described above.
The limit, in reality, will be whatever range you might be able to achieve given the link budget and performance expectations of the deployment. You can use LINKPlanner to model it out and give you an idea of performance expectations in the real world.
