What is the Maximum LOS distance should the epmp get with 90 degree sectors and a standard cpe?
Curt,
To answer your question it would depend on the country you are in so you don’t exceed the maximum EIRP. In regards to the EIRP, it would also depend on the AP’s transmit power setting and the Antenna Gain configured for your 90 degree antenna. For the Cambium supplied antenna, the antenna gain is 15 Dbi.
Our Link budget tool for ePMP might give you better insight on the distances you can obtain. The “ePMP Link Budget Calculator Tool created for Excel” can be obtained from here: https://support.cambiumnetworks.com/files/epmp
