We deployed 4 450M AP's today and we are unable to run a spectrum scan on two of them. Has anyone else had this issue?
I am assuming the spectrum analysis you are trying is on the device GUI right?
Are you running the latest firmware, and/or did you configure a frequency first in the AP?
I want to say I remember a bug where with early firmware spectrum analysis would run into problems if a frequency was not selected first.
I hope this helps.
a couple of reboots later it started working properly, firmware is currently 15.1.3. . Thanks for the reply
I've had the same issue before with various types of AP's. If it uses a CMM, rebooting the CMM sometimes makes it work correctly.
