Mesh Wifi / cnMaestro solution
Is their a solution in the works for a Home Wifi mesh system? or maybe some firmware that will make it easy to mesh two or three r195w’s together?
R190w does Not support mesh, for this purpose you should use the ”E” family of cnPilot, I have been using e410 and it works flawlessly for two years withouth any issue.
