What’s the minimum separation I should have between a 2.4 cluster and a 150 Mhz VHF antenna? Can they be in the same plane?
I would say there really is no such thing as minimum separation. There are too many factors and variables.
I would try to keep as much separation as possible between the Canopy and the VHF antenna.
I guess the main concern is, can I mount equipment on the same plane at the VHF antenna? The thing is like 20 feet tall so its hard to avoid it.
The answer should be yes, it can be done.
If using 900 MHz, do a site survey first, check the noise level arround that tower.
trial and error… try it and see what happens…
I have sat on FM towers with no problem, and very close to AM towers without issues…
