What are the minimum distances recommended between a PMP link without Lens/Reflector Dish?
Abeelash,
We provide link budget tables in our Planning Guides. Since you did not specify the product you are using you can download our PMP 450 Planning Guide here : https://support.cambiumnetworks.com/files/pmp450
The planning guide will give you the range you are looking for as well as the sensitivity needed to maintain performance or throughput.
