Hello,
We are new to Camblium equipment. We installed some 450i AP’s and we have a client connected to the AP via a 450B SM. From cnMaestro when we do a link test, we are seeing speeds that are changing… from 28Mbps dowload to 98Mbp dowload…this is a big swing… generally when we do the first test it seems to be lower. Then when we test again it is higher.
When I plug a laptop of ours directly into the POE module, we never get above 32Mbps and usually, it is lower than that when we test from speedtest.net and fast.com.
A couple of other things:
- This is the first client connected to the 450I
- The client has perfect clear line of sight and is at 307 feet from the AP.
- I did notice that from cnMaestro it showed the following:
– numerous session drops
– Modulation seems to be all over the place from 8X Mimo-B to 1X Mimo-A
Not really sure what I have missed or where I should start digging or if I have missed a setting.
Any help would be greatly appreciated.
