Missing OIDs addVlanMember.0 and removeVlanMember.0 in 13.4 release
On the PMP450 the following Object Identifier are missing:
addVlanMember.0 (.1.3.6.1.4.1.161.19.3.3.2.20.0)
removeVlanMember.0 (.1.3.6.1.4.1.161.19.3.3.2.21.0)
SNMP Walks:
13.4
# snmpwalk -v2c -c Canopy 169.254.1.2 .1.3.6.1.4.1.161 | grep -i Vlan
WHISP-APS-MIB::vlanEnable.0 = INTEGER: enable(1)
WHISP-APS-MIB::apVlanOverride.0 = INTEGER: disable(0)
WHISP-BOX-MIBV2-MIB::vlanMemberSource.0 = INTEGER: configured(0)
13.2.1
# snmpwalk -v2c -c Canopy 169.254.1.3 .1.3.6.1.4.1.161 | grep -i Vlan
WHISP-BOX-MIBV2-MIB::addVlanMember.0 = INTEGER: 1
WHISP-BOX-MIBV2-MIB::removeVlanMember.0 = INTEGER: 1
If you try to set the value:
13.4
# snmpset -v 2c -c Canopy 169.254.1.2 addVlanMember.0 i 666
Timeout: No Response from 169.254.1.2
13.2.1
# snmpset -v 2c -c Canopy 169.254.1.3 addVlanMember.0 i 666
WHISP-BOX-MIBV2-MIB::addVlanMember.0 = INTEGER: 666
13.4.1 open beta is released which fixes this issue
https://support.cambiumnetworks.com/files/pmp450/beta
Please give it a try.
@Chitrang wrote:
It works now, thank you.
