Mobile CPU power consumption benchmark
Hi All,
I have to determine the power consumption of the CPU (a part of the SOC)for a series of smart phones (e.g. Nokia, BlackBerry, Motorola and HTC). My problem is that I don’t have the perfect solution to do this but and old fashion one using an amp meter to measure the current on stand-by and after that during the execution of a test software program. More specifically I must measure the power consumption for each phone while running a series of Java benchmarks (for example GrinderBench).
To obtain the measurements I searched for software that helps you measure your phone’s power consumption. For example I found: â€
I think you are in the wrong forum… This is for Motorola Canopy Wireless Broadband.
With that said, why are you re-inventing the wheel? The manufacturers have already done this work for you, all you need to do is get the info from engineering.
