seems as tho this stuff is like a soap opera and the saga continues.newest adventure.layer two upgrade no longer works after upgrade it will register on the ap but will not pass internet to the sm and the sm is assigning an ip address to the computer even tho its set to bridge mode with the latest upgrade even tho the first 4 sm’s we used for customers continue to work.agggg anyone seens this?
Did you upgrade from e1.1 to e2.0.1 and then change from Layer3 to Bridge Mode? Did you follow the Layer 3 to Layer 2 Migration Document?
https://docs.google.com/fileview?id=0B03Iz1yodeFuOTU1N2NjYTMtMjkxMS00NDkyLWE1M2EtMzIzYzA3NzFmZjcw&hl=en&authkey=CL218PQF
It is obvious that something with the AP config has become corrupt. I have found it necessary to clear the browser cache prior to making any changes on the Access Point.
