Is there any way to view the following info via Prizm:
- re-registration counts for SMs
- Using NAT with DHCP Client enabled - can you view the customers CPE Public IP?
I have looked through the columns and was unable to find either option.
re-registration counts for SMs - this is really something only the AP can keep up with. I don’t think prizm is currently able to poll one unit and then write stats to another unit with what it finds. Would be nice though.
Using NAT with DHCP Client enabled - can you view the customers CPE Public IP? - I probably don’t understand the question but if you have DHCP client enabled the customer CPE won’t have a public IP. Other than that, There is a facility in Canopy to grab router’s arp tables. You can then search by IP. Haven’t done it though.
