Any body have any data on whether you can put a couple Motorola 5440APAA on the same tower as 5450APs and have them play nice together? (in same vertical space as well)
-Paul
What’s the 5440? New non-advantage? It should work fine if you keep your downlink % and control slots the same.
If they point in the same direction, then make sure to use different frequencies
Might be tight. Might want to wait for the 5.2 and/or 5.7 400 stuff.
