Hi there,
Can the XV3-8 APs use the same mounts as the E600 models?
Hi there,
Bump. We have some E600 APs mounted with ceiling tile mounts. Can these be used with the newer model APs?
no XV3-8 uses a different mounting bracket than the e600 since it is a much larger unit and heavier.
The bracket on the XV3-8 and XV2-2 is different than the e600 and e410 since the Wifi 6 Access Points are larger and heavier.
