Perl 5.6
mrtg-2.12.0
windows 2003
Hi Forum, i have problems with mrtg and canopy, have the mrtg monitoring my switches and routers this is run very good but i have problems with the canopy sm´s, i unloaded the manual de canopy and mrtg and the mibs (6.1) but no run. This is my .cfg
------------------------------22.cfg-------------------------------------------
LoadMIBs: canopymibs/SNMPv2-CONF.txt,canopymibs/SNMPv2-SMI.txt,canopymibs/SNMPv2-TC.txt,canopymibs/whisp-tcv2-mib.txt,canopymibs/WHISP-GLOBAL-REGMIB.txt,canopymibs/WHISP-BOX-MIBV2-MIB.txt,canopymibs/WHISP-APSMIB.txt,canopymibs/WHISP-SM-MIB.txt,canopymibs/CMM3-MIB.txt
WorkDir: c:'InetPub’wwwroot’MRTG
RunAsDaemon: yes
############### < Device = SM 1 at Test Location > #######################################
### sm_rex:Ethernet Interface Traffic
Target[sm_rex-eth_int]:2:Canopy@sm_rex:::::2
Directory[sm_rex-eth_int]:sm_rex
MaxBytes[sm_rex-eth_int]:12500000
Title[sm_rex-eth_int]:Traffic Analysis for sm_rex - Ethernet Interface
PageTop[sm_rex-eth_int]:<H1><A Href=“http://sm_rex"target=”_blank">sm_rex - Ethernet Interface</A></H1>
<TABLE>
<TR><TD>Device:</TD> <TD>Canopy Subscriber Module</TD></TR>
<TR><TD>Max Speed:</TD> <TD>7.5 MBytes/s</TD></TR>
<TR><TD>Description:</TD> <TD>Sm rex at Someplace</TD></TR>
</TABLE>
### sm_rex:RF Interface Traffic
Target[sm_rex-rf_int]:1:Canopy@sm_rex:::::2
Directory[sm_rex-rf_int]:sm_rex
MaxBytes[sm_rex-rf_int]:12500000
Title[sm_rex-rf_int]:Traffic Analysis for sm_rex - RF Interface
PageTop[sm_rex-rf_int]:<H1><A Href=“http://sm_rex"target=”_blank">sm_rex - RF Interface</A></H1>
<TABLE>
<TR><TD>Description:</TD> <TD>SM 1 at Someplace</TD></TR>
</TABLE>
### sm_rex:Rssi
Target[sm_rex-rssi]:rssi.0&rssi.0:Canopy@sm_rex:::::2
MaxBytes[sm_rex-rssi]:3000
Directory[sm_rex-rssi]:sm_rex
Title[sm_rex-rssi]:RSSI Analysis for sm_rex
Options[sm_rex-rssi]:gauge, nopercent, absolute
Unscaled[sm_rex-rssi]:dwmy
YLegend[sm_rex-rssi]:Rssi
LegendI[sm_rex-rssi]: RSSI:
LegendO[sm_rex-rssi]: RSSI:
ShortLegend[sm_rex-rssi]:Rssi
Legend1[sm_rex-rssi]:RSSI
Legend2[sm_rex-rssi]:RSSI
PageTop[sm_rex-rssi]:<H1><A Href=“http://sm_rex"target=”_blank">sm_rex - RSSI</A></H1>
<TABLE>
</TABLE>
### sm_rex:Jitter
Target[sm_rex-jitter]:jitter.0&jitter.0:Canopy@sm_rex:::::2
MaxBytes[sm_rex-jitter]:15
Directory[sm_rex-jitter]:sm_rex
Title[sm_rex-jitter]:Jitter Analysis for sm_rex
Options[sm_rex-jitter]:gauge, nopercent, absolute
Unscaled[sm_rex-jitter]:dwmy
YLegend[sm_rex-jitter]: Jitter
LegendI[sm_rex-jitter]: Jitter:
LegendO[sm_rex-jitter]: Jitter:
ShortLegend[sm_rex-jitter]:Jitter
Legend1[sm_rex-jitter]:Jitter
Legend2[sm_rex-jitter]:Jitter
PageTop[sm_rex-jitter]:<H1><A Href=“http://sm_rex"target=”_blank">sm_rex - Jitter</A></H1>
<TABLE>
</TABLE>
Workdir: C:'Inetpub’wwwroot’MRTG
-----------------------------command error--------------------------------------
i´m put this command and return this
C:'mrtg-2.12.0’bin>perl cfgmaker Canopy@100.100.1.22 --global “WorkDir: C:'Inetpub’wwwroot’MRTG” --output 22.cfg
–base: Get Device Info on Canopy@100.100.1.22:
SNMP Error:
no response received
SNMPv1_Session (remote host: “100.100.1.22” [100.100.1.22].161)
community: “Canopy”
request ID: -1096802309
PDU bufsize: 8000 bytes
timeout: 2s
retries: 5
backoff: 1)
SNMPWALK Problem for 1.3.6.1.2.1.1 on Canopy@100.100.1.22::::::v4only
WARNING: Skipping Canopy@100.100.1.22: as no info could be retrieved
–base: Writing 22.cfg
This create folders but no more.
And i´m have questions with the configuration of sm or ap in the snmp configuration, in SNMP is Canopy and network 0.0.0.0 /24, down 0.0.0.0 and enable el only read, this is right?
Please help me and excuseme my english.
You need NET-SNMP installed as well to monitor SM’s, BH’s and AP’s. Works great over here. I use the Schedule task manager and run a batch file every 5 minutes that updates the images. Pretty sweet.
