I am using FreeBSD4.x, mrtg-2.11.0, perl 5.8.5
MRTG File:
# The correct directory path in each should be specified.
Htmldir: /usr/local/etc/mrtg/data/
Imagedir: /usr/local/etc/mrtg/data/images/
Logdir: /usr/local/etc/mrtg/data/logs/
LoadMIBs: canopymibs/WHISP-APS-MIB.txt,canopymibs/WHISP-BOX-MIBV2-MIB.txt,canopym
ibs/WHISP-GLOBAL-REG-MIB.txt,canopymibs/WHISP-SM-MIB.txt,canopymibs/whisp-tcv2-mi
b.txt
Target[sb_250_regcount]: regCount.0®Count.0:Palmenberg@10.253.2.250:::::2
Options[sb_250_regcount]: nobanner, gauge, nopercent, absolute
MaxBytes[sb_250_regcount]: 200
Directory[sb_250_regcount]: clients/wireless
Title[sb_250_regcount]: Registration Count for AP
PageTop[sb_250_regcount]: <H1>Registration Count for AP on Shaw Butte Mountain</H1>
<TABLE>
<TR><TD><b>Frequency:</b></TD><TD>5.2GHz</TD></TR>
<TR><TD><b>IP Address:</b></TD><TD>10.253.2.250</TD></TR>
<TR><TD><b>Max Connections:</b></TD><TD>200</TD></TR>
</TABLE>
Error Reported:
bigguy# mrtg canopy.cfg
Use of uninitialized value in concatenation (.) or string at /usr/local/lib/perl5/site_perl/5.8.5/SNMP_util.pm line 1266, <MIB> line 66.
Use of uninitialized value in concatenation (.) or string at /usr/local/lib/perl5/site_perl/5.8.5/SNMP_util.pm line 1266, <MIB> line 71.
Use of uninitialized value in concatenation (.) or string at /usr/local/lib/perl5/site_perl/5.8.5/SNMP_util.pm line 1266, <MIB> line 72.
Use of uninitialized value in concatenation (.) or string at /usr/local/lib/perl5/site_perl/5.8.5/SNMP_util.pm line 1266, <MIB> line 73.
Use of uninitialized value in concatenation (.) or string at /usr/local/lib/perl5/site_perl/5.8.5/SNMP_util.pm line 1266, <MIB> line 74.
Use of uninitialized value in concatenation (.) or string at /usr/local/lib/perl5/site_perl/5.8.5/SNMP_util.pm line 1266, <MIB> line 75.
Use of uninitialized value in concatenation (.) or string at /usr/local/lib/perl5/site_perl/5.8.5/SNMP_util.pm line 1266, <MIB> line 76.
Use of uninitialized value in concatenation (.) or string at /usr/local/lib/perl5/site_perl/5.8.5/SNMP_util.pm line 1266, <MIB> line 755.
Use of uninitialized value in concatenation (.) or string at /usr/local/lib/perl5/site_perl/5.8.5/SNMP_util.pm line 1266, <MIB> line 1432.
Use of uninitialized value in concatenation (.) or string at /usr/local/lib/perl5/site_perl/5.8.5/SNMP_util.pm line 1266, <MIB> line 1437.
Use of uninitialized value in concatenation (.) or string at /usr/local/lib/perl5/site_perl/5.8.5/SNMP_util.pm line 1266, <MIB> line 1438.
Use of uninitialized value in concatenation (.) or string at /usr/local/lib/perl5/site_perl/5.8.5/SNMP_util.pm line 1266, <MIB> line 1439.
Use of uninitialized value in concatenation (.) or string at /usr/local/lib/perl5/site_perl/5.8.5/SNMP_util.pm line 1266, <MIB> line 1440.
Use of uninitialized value in concatenation (.) or string at /usr/local/lib/perl5/site_perl/5.8.5/SNMP_util.pm line 1266, <MIB> line 1441.
Use of uninitialized value in concatenation (.) or string at /usr/local/lib/perl5/site_perl/5.8.5/SNMP_util.pm line 1266, <MIB> line 1442.
Use of uninitialized value in concatenation (.) or string at /usr/local/lib/perl5/site_perl/5.8.5/SNMP_util.pm line 1266, <MIB> line 2121.
cannot encode Object ID .7.1.0: first subid too big in Object ID 7.1.0 at /usr/local/bin/mrtg line 1849
ERROR: Target[sb_250_regcount][IN] ’ $target->[0]{$mode} ’ did not eval into defined data
ERROR: Target[sb_250_regcount][OUT] ’ $target->[0]{$mode} ’ did not eval into defined data
I have the same problem, not like solving it.
