MTI Wireless Edge
Anyone have anything to say about MTI Wireless Edge?
I am looking at adding a narrow 900MHz sector to shoot up a valley using this antenna:
http://www.mtiwe.com/data%5Cimages%5Cpr … 06n_v2.pdf
Thoughts, comments, good, bad, whatever?
Well the stats look decent i once used one of those little square maxrad 10 db’s to do about what your saying for a test and it worked fine.
kmeadows
Info-Ed Inc.
i have a mti flat panel working doing just that shooting down a valley.
the throughput is great but its a big beast. wind loads are huge but they are built very beefy. and the base mount it comes with is really beefy as well.
just my 2 cents.
Thanks, that was exactly what I was looking for.
Ordered it and will install it next week.
